Engine, VSC & Trac lights all on
cnl390
The Check Engine, VSC & Trac lights are all on, but I am not sure if there really is problem.
I get the P0430 code but the stats are as follows...
Air flow rate for Mass Flow Sensor 7.30-7.40
Bank 1 Sensor 1 (Wide range O2s) Equivalence Ratio .996-1.005
Bank 1 Sensor 1 Voltage 3.229-3.323
Bank 2 Sensor 2 (Wide range O2s) Equivalence Ratio .994-1.007
Bank 2 Sensor 2 Voltage 3.265-3.320
Catalyst Temperature Bank 1 Sensor 1 468 C
Catalyst Temperature Bank 1 Sensor 2 237 C
Catalyst Temperature Bank 2 Sensor 1 468 C
Catalyst Temperature Bank 2 Sensor 2 237 C
What Year, Trim, and Engine is this vehicle?
Also what are the following data values for the following information when you took the above measurements:
  • RPM
  • Battery Voltage
  • ECT (Engine Coolant Temperature)
  • Atmospheric Pressure (and/or your altitude if it is more than about 1000ft above sea level)
  • STFT (Short Term Fuel Trim)
  • LTFT (Long Term Fuel Trim)
  • Total FT (Assuming your scantool actually shows this, if it doesn't its okay]
  • Fuel system status (Closed Loop or Open Loop)
  • IAT (Intake Air Temperature)
  • B1S1 Impedance (If your scantool shows this value)
  • B1S2 Impedance (If your scantool shows this value)
  • B2S1 Impedance (If your scantool shows this value)
  • B2S2 Impedance (If your scantool shows this value)
  • Voltage for B1S2 O2 Sensor
  • Voltage for B2S2 O2 Sensor
My rough guess there is that your engine is running extremely lean, those voltages are pretty much pegged Lean. I'm surprised you don't have any lean codes at the moment.
We need more information, particularly what both front and rear sensors are seeing as well as what the engine is doing, what temperature it's at, what the ECM thinks it's doing/seeing, ect.
If you give the Catalytic Converter section of the link provided below, it should help you understand all the information we want to look at to narrow down the possible cause of the P0430 DTC.
http://www.toyota-4runner.org/4th-gen-t4rs/132953-toolbox-how-use.html#post1272379
Here are additional stats... (I did not include reading from previous post)
Calculated engine load 30.2%
Coolant Temp 85 C
Short term fuel trim Bank 1 3.9%
Long term fuel trim Bank 1 -4.7%
Short term fuel trim Bank 2 3.9%
Long term fuel trim Bank 2 -4.7%
RPM 710
Timing #1 15.0
Air flow mass sensor 3.65 g/s
Absolute Throttle position 16.9%
Bank 1 Sensor 2 Output voltage .565 v
Bank 1 Sensor 2 Short term trim 0.0%
Bank 2 Sensor 2 Output voltage .640 v
Bank 2 Sensor 2 Short term trim 0.0%
Barometric pressure 98 kPA
Bank 1 Sensor 1 Current 0.004 mA
Bank 2 Sensor 1 Current 0.012 mA
Cat Temp Bank 1 Sensor 1 395 C
Cat Temp Bank 1 Sensor 2 209 C
Cat Temp Bank 2 Sensor 1 394 C
Cat Temp Bank 2 Sensor 2 209 C
Control Module 13.30 v
Absolute load 12.57
Fuel/air commanded equiv, ratio .954
Absolute evap vapor 99.015 kPA
Fuel consumption .51/100 Km
Philthyphilthy
