Ethanol Fuel mixing
LC_4R
I was wondering if I am the only one that has tried mixing E85 with pump gas to run 'E'-mix?
I find that the V6 4Runner can run up to 'E30' very well and achieve very comparable MPG. I only do this in warm-to-hot weather. I have done this for about 3 years now. I have modified my K&N air filter setup to draw underhood (warm) air to help run the 'eth'. In extremely hot summer weather, I have run up to E40 mix.
Any other eth-users?
Ethanol
I bought a ethanol converter so I can run on gas or ethanol. I am going to try to produce my own at home. Trying to save money. I hear the only issue that you might have is getting water in your fueling system. The water can cause rust. So I am going to buy a water separator/ fuel filter.
I'll use it if the following happen. I get the APR 680 fuel injectors and it becomes more widely available in my area and it costs alot less than regular pump gas.
