ethanol grade?
thorridder
i have started to some major mods to my 4runner and am needing to squeeze as much power out of her as possible. wondering if there is any real difference from 87 to 91 gas grade.
and any other tips you have for power?
Get the fuel with the lowest amount of Ethanol as possible (ethanol blows), I've heard that jumping grade doesnt do much for power, but i could be wrong.
There is potential by going to a higher grade of fuel but to really benefit from it you need to tune it. Ethanol (e85) has a higher a higher octane rating, it ranges anywhere from 100-105 in terms of octane levels. however you will lose fuel economy somewhere around 20-30 percent. so far I've been running up to e10 gasoline in my truck, it just depends whatever they put in there.
I know they put ethanol on gasoline. I know Shell does @ 10 percent (as per what is advertised at their pumps).
Ethanol
The ethanol content and octane rating are two different things. Most gasoline here is sold with 10 percent ethanol (E10), and I have yet to see any unleaded gasoline without it anywhere in this area.
Octane ratings range from 87 for regular to 92 or 93 for most premium unleaded around here. Most stations also sell a "mid-grade" fuel with an octane rating of 89. All have 10 percent ethanol.
Ethanol (ethyl alcohol) has a very high "octane" rating itself and would be great for racing applications or very high compression ratios & advanced ignition timing. However, alcohol has far fewer BTUs than gasoline; thus negatively affecting your fuel economy.
In PA, they sell E85 (85 percent ethanol and 15 percent gasoline) for about sixty cents a gallon less than regular unleaded.......but your fuel economy suffers significantly. It is a wash at best, I suppose; and only "flex fuel" vehicles can run on E85. It will destroy a 'regular car' in short order.
Stick to 100 percent gasoline if it is available in your market!
87 to 91 doesnt have the best increase in power but if you add some octan booster you'll feel a differnce.. i have question for you now.. im new and can figure out how to post a question can you help me out
