Ever repaired the HomeLink on the 3rd Gen?
BamaDrewski
Found some visors off a 2001 T4R in good shape. Hooked the driver's side up with power (pulled the harness as well as the visor). The HomeLink (3 button model) does not light up though and can't get it to work.
Anyone else every experienced this and fixed it? If so, any help is appreciated!!!
I doubt it. You can't even get to the transmitter without tearing up the visor, and even then, I don't know how you'd go about trying to repair the transmitter.
ETA - the light is only supposed to come on when a button is depressed.
I found a set of those visors for [MENTION=71960]JohnMc[/MENTION] , he got the homelink working....though he didn't seem to have any problem with it not working. Maybe he'll reply. Don't know that he'll be able to help with your situation.
The little red light comes on when a button is pressed. We found programming instructions online and it was easy- just have to have a door that will work with it.
All I did to get it working (wiring-wise) was to just add some wiring from the passenger side mirror (which seems to always be on) over to the driver's side, paying attention to neg and positive.
At that point, I could see the little red LED lighting up when I pressed the buttons.
Then we went through the programming instructions, first with the remote and the visor, and then pressing the button on the opener itself, and voila, like magic, it started working.
Only thing of note past that is that I've noticed there is a slight delay when pressing the visor button to open the garage door. Seems like the 'real' remote you just click it, but you have to hold the button on the visor down a little longer. A slight click and hold, until you see the garage door move. If you just press it quickly, it's not going to do anything.
Is the light on the mirror working on the Homelink visor? Since there's only one pair of 12V+/ground wires going to the visor, they obviously share the same power source.
Also, I'm not sure if the Homelink hardware in the visor would lose its programming if you have it on switched 12V power, so it powers completely down when the car is turned off. Mine is wired to unswitched 12V+ - the visor mirror lights work all the time.
No, it WILL maintain the code with no power. I changed it on my 2017 F250 to be hot only when key is ON.. I also added one to my sons 3rd gen and have it to be hot only when the key is on.
I attached the homelink wires directly to the battery to test it prior to wiring it up. If you don’t have lights flashing on the homelink when attached directly to battery then you have a non working unit.
