The 5th gen doesn't get the sulfur smell since it doesn't have a resonator like the 4th gen. What you are smelling is just the new exhaust it will go away after awhile
I bet to differ - had mine 11 months & 8k, if I step on it with the back window down....wow strong 'sulfur' smell. If you get out of the 4R shortly after that you can smell it for a few minutes standing next to it.
actually, the sulfur smell on the 4G was due to the catalytic converter, and the 5G obviously has one of those. there was a TSB issued for the 4G; customers who experienced the rotten egg smell (and/or complained/knew about the TSB) had their cats replaced.The 5th gen doesn't get the sulfur smell since it doesn't have a resonator like the 4th gen. What you are smelling is just the new exhaust it will go away after awhile
that's why it was a TSB and not a recall: not everyone experienced it.Never had my cat replaced and I owned it from 04 until 2010?
I recall someone posting that they had replaced the headers and the rotten egg smell had gone away. Logic would say that if this were true then the rotten egg smell is coming from the first set of cats.
my '06 stunk a bit when you really stepped on it with the rear window down. but the reality is that the exhaust routed straight out the back (and not to the side) simply has a tendency to draw some exhaust in the rear when the window is down due to the airflow pattern of the moving vehicle.
hamilton, where does your aftermarket exhaust exit? Is it different then where the tip normally comes out?
I know on the 4th gen section one of the moderators had the smell he cut off the resonator and routed the exhaust out the side and the smell was gone.
