Exhaust stink!
Some1esle
Replaced the stock exhaust about 4 or 5 months ago with 3 inch in flowmaster cat, 2.25 inch pipe about 12 to 18 inches, then a flowmaster delta 50, 3 inch tailpipe, the $12 tip from Walmart or something... the manifolds, and y-pipe are bone stock. the intake is stock with a drop in K&N. This setup was recommended by the guys at Flowmaster.
Ok now to the problem:
aside from an idle problem, the truck runs great, sounds like it has nuts the size of a taxicab, and has greatly improved HP. The exhaust smell like a cross between rotten eggs, sulfer, and ass. this is only when the vehicle is warm. and in southern Arkansas that seems to be 99.9% of the time.
Any Ideas...
it was NEW right ?
I would think you have and issue with the exhaust size? and computer control... maybe tuning is required ?
depending on the year of your unit .. i'd say some adjustments are required with the "larger" exhaust .
slacker said:
it was NEW right ?
I see... I need to do some tuning , so It will probably workout in that.
Did you pull the efi fuse for a few seconds after you got the exhaust done?
It can help to reset the ECU so it relearns the fuel curve sometimes. With increased exhaust flow there will be a need for more fuel.
Other than that, that may just be a side effect of a high flow cat. If you think that's bad you should smell mine without a cat at all. :awais:
EFI fuse... I had the 3 in pipes all the way back at first.... Yep, it was worse. I also experienced a major lose of power due to lack back pressure. That's why I dropped back down to 2.5 before the cat, and 2.25 between the cat and the muff. Oh ya I also had the Delta 40 single chamber on there before as well. I changed out to delta 50 three chamber muff. I will do the efi fuse removal. That could be a big part of my low idle as well. Then I'm going to change out to the AMSOil air filter, from the K&N after reading some results on those.. Yep, I'll check the MAF door/gate at the same time, and grease it with white lithium. Then professionally timed, and tuned.. See what happens from there...
Just out of curiosity, how much did that exhaust setup cost you? I'm looking for a few hp for my 3.slow so am researching 2.25-2.5 inch catback exhaust systems.
And yes, a smelly cat is usually a sign of a bad cat, or bad tuning (too rich). Since your cat is new, and you're experiencing other issues, sounds like bad tuning.
ian
