Extended crank issue 3.4l
If extended crank issue occurs. I would check the fuel pressure at the rail. Make sure your fuel filter is good. Granted this is after a through check of ignition system as well.
had installed brand new OEM fuel pressure regular, denso fuel pump, and OEM fuel filter beforehand. as i said i diagnosed and repaired the issue
same here...would like part #s...aftermarket? By the way I'm back with a slightly different handle and low post count since my house burned down. Starting over on all accounts.
OEM Toyota Part #: 23250-62030
i obviously only recommend OEM Toyota injectors if you havent taken a look at my build thread. im pretty against aftermarket cheaper parts.
H.Sikina
