F wheel & R axle bearing/seal numbers?
msimmons
I found 4th Gen front wheeel bearing numbers (515040) here on the site, anyone know if the rear axle bearings are also 515040's?
Same question for the outer seals, front is OEM PN 90312-96001... same for the rear? (see update below)
I have two '04 T4R's, but specifically working on my 2004 4Runner Sport v6 2WD.
UPDATE:
I answered part of my own question: Here are the Toyota PNs for 2004 4Runner Sport v6 2WD
source: http://www.toyotapartszone.com using my VIN.
SEAL, OIL (FOR REAR AXLE SHAFT RH) 90310-58003
SEAL, OIL (FOR REAR AXLE SHAFT LH) 90310-58003
RING, O (FOR REAR AXLE BEARING CASE RH) 90301-83002
RING, O (FOR REAR AXLE BEARING CASE LH) 90301-83002
GASKET, BRAKE DRUM OIL DEFLECTOR, RH 42443-60010
GASKET, BRAKE DRUM OIL DEFLECTOR, LH 42443-60010
RING, SNAP (FOR REAR AXLE SHAFT RH) 90520-41019
RING, SNAP (FOR REAR AXLE SHAFT LH) 90520-41019
WASHER(FOR REAR AXLE SHAFT RH) 90208-44001
WASHER (FOR REAR AXLE SHAFT LH) 90208-44001
