FS 3rd Gen 4R Limited 4x4 $12,500 Northern Alabama
Kokomodo
Junior Member
FS 1999 3rd Gen 4R Limited 4x4 279,xxx miles. Lots of preventative high mileage care has already been performed in the last two or three years including:
New timing belt and water pump
New radiator
New front knuckles with wheel bearings
New front axles
New sway bar links
New valve cover gaskets
New knock sensors and cable
New heater valve Bowden cable and motor actuator
New brakes (rotors, pads, drums, shoes, wheel cylinders, flush and fill)
New differential wheel bearing kit
New driver's side rear wheel bearings and seals
New shocks (Bilstein)
Sunroof drains cleared and cleaned.
Vehicle is in very good condition. 4WD has been engaged monthly per the manual. Oil changed regularly. I'm selling because I'm now an empty nester and we no longer need it. I am not the first owner. Car runs and drives well. All work performed by a professional shop or a dealer. I think the only thing that doesn't work on the vehicle is the driver's door automatic lock. I live in northern Alabama. Two keys.
thadjay
