Factory Off Road Traction Options - Please Read
rkwfxd
Hey Folks,
I am trying to create a bit of a cheat sheet for myself to help me get a good handle on what buttons to push, what traction control options are available off road. Could some of you please take a look at the below and let me know if I have it correct or if I am missing something?
For instance, I believe Muti-Terrain is avail in 4H but only the Mud and Sand Options. I also know that in Crawl Control Multi-Terrain is not available. I have played with this stuff off-road (prior to studying the manual) and sort of kind of maybe figured it out. Then I came home and read through the manual and watched a couple of videos.
But I may have missed something.
I'd also like some input on what the community goes to first. For example, when you are in 4LO and loose traction do you push the A-Trac, Rear Locker, or Crawl Control First. If that doesn't work, what is your next go to/
Obviously Red means that function is not available while in that mode.
2H
4H
Multi-Terrain
Mud/Sand/Snow
Loose Rocks
Moguls
Rocks
Rear Locker
Crawl Control
A-Trac
4L
Multi-Terrain
Mud/Sand/Snow
Loose Rocks
Moguls
Rocks
Crawl Control
Rear Locker
A-Trac
Crawl Control
1 kph
2 kph
3 kph
4 kph
5 kph
Multi-Terrain
Rear Locker
A-Trac
Rear Locker
A-Trac - Only works on front brakes.
Multi-Terrain
Crawl Control
A-Trac
Multi-Terrain
Crawl Control
Rear Locker
Looks good to me other than your CRAWL Control speeds are in kilometers per hour, not mph. So highest setting (5) would equate to about 3 mph. And you can use A-trac with the rear locked. It simply works the front brakes in that case since the rears won't spin away from each other.
My order of progression is multi-terrain mud/sand, A-trac, rear locked, and then CRAWL if all else fails.
Thank you
Corrections made.
Depending on the "GoTo" order for most folks I will change the order on my list.
Question: You listed MT Mud/Sand first - Is that in 4HI?
[MENTION=50362]jayhat[/MENTION] did it first, but a quick, users guide for the different systems. How to engage, and conditions used for:
(unfortunately, my location doesn't let me get into google docs, so can't see if it's still up, but Jay definitely deserves uber credit for this).
http://www.toyota-4runner.org/5th-g...t-know-about-your-4runner-48.html#post2752311
If not, there's a pdf version from [MENTION=137310]MasonCO[/MENTION]
http://www.toyota-4runner.org/5th-g...t-know-about-your-4runner-51.html#post2791697
EDIT: This is a quick guide only. This is not a substitute for the classes, going out and trying the stuff in controlled situations, or going out with seasoned/experienced people. The best system is still between the ears.
Nice someone cleaned up my typos lol. I was too lazy to go back and edit it. I am not sure what else he changed, but it's cool. Thanks for the mention.
This is helpful. Thank you.
I am one of those guys who puts it in 4Hi as soon as I get on dirt and leaves it there until I am done for the weekend trip/event (I have no manly need to prove what I can do in 2Hi). So while it is possible I don't typically use multi-terrain in 4Hi.
I am also one of those guys who usually puts it in 4Lo once I start on one of the tight twisty trails we typically get here in the piney woods. I consider it easier on the drivetrain and I can use the engine and shifter as a brake instead of dragging my brakes with the pedal. Then depending on the trail and what I know about it I might start with mud/sand and go from there.
M+S works well in slick stuff in 4hi, not aggressive like atrac when some slip is okay
Sent from my SM-G930V using Tapatalk
