Fan resistor question...
2Walker5RS
Got a quick question...
My Heater-A/C Fan (2nd gen 92) will only run on High and I'm assuming its either the fan itself or the speed resistor... My question is weather the resistor is remote or built into the motor itself?
Thanks!
Alrighty, I just did e-Bay research, found a resistor and its on its own... :thumb3: I assume it would be located around the ECU somewhere...?
Looks like everyone's trying to get the heaters fixed for winter... I was having this issue of only high also but my blower only worked intermittently anyway, and seems to have finally conked out for good.
About to try and see if the motor is even getting power, if yes, did replacing your resistor fix your issue?
Yep, got one of e-Bay for $20, fixed the prob! Hope you get yours fixed! I can defrost my windshild now!!!
