Farting noise from under the hood?
Recoil Rob
Ever since I got my 97 Limited (used) it has had a slight farting noise from under the hood, about every 5 seconds it emits a low buzz for about 1 sec. This is with the car standing in the driveway, everything off and no key in the ignition.
I still know the original owner and they told me it did that when it was new from the factory.
Today I noticed it's now changed to a constant low buzz/humm noise. I have to think that whatever it is is going to eventually drain the battery so I put an Amp draw test on it but there's nothing there, .02 A.
The truck came with a Lo-Jac system installed, could that be it?
thanks,
Rob
thanks,
Rob
Make a video clearly showing the sound.
I suspect the worst :(
You've got a ricer living under your hood, man...
Cars like that gives Honda its bad name. But I guess "to each his own".
If it's been like that since you got the 4runner and you haven't had a dead battery. I wouldn't worry to much about it. The sound probably goes away after a while (20min) or so??? Probably just the canister purge valve releasing some built up pressure in the evap system.
I just ran the part number through 1sttoyotaparts and it had it listed....could try and order it, I've never heard they were discontinued.
77701-35010
I bet you could achieve the same thing by putting a inline metal or plastic fuel filter on the hose.
