February Shrockworks Group Buy
On my 2014 SR5 I don't have threaded holes on the 2 outer holes on the drivers rear (the ones next to the gas tank). Any recommendations on how to get a sticky nut on those?
You are going to have to put the sticknut through the access hole that is on the bottom of the frame just forward of the holes. I believe I did the top one first and then the lower one, but it may be easier the other way around. It's a lot of trial and error to get the nut lined up with the hole just right. I used a flashlight from the outside so I could see when the nut was aligned with the hole. You'll also probably have to trim some of the excess metal around the nut in order for it to fit through the access hole.
My advice is to just tighten them slowly once you get the bolt threaded in the nut. If you start to feel the nut pull the tab of the sticknut as you are tightening the bolt, examine the situation as best you can to make sure you don't lose the tab into the frame like I did before the bolt is tight.
Skid plates
Is it my imagination or do the Schrockworks full skid plates make my 2014 limited significantly quieter? Has anyone else experienced this added benefit? Maybe it is just the justification portion of my brain at work...
Wasn't there recently a group buy at the end of 2014? Might be a bit hard, but if there's enough interest I don't see why they would turn down money.
I finally got a reply back and they can build my receiver hitch. Who do I need to pm on this to see if I can get the bumper I want on this order?
REE
