Fender height on TRD pro with toytec 2" lift
TRDpro4R
To those with a TRD pro that did the toytec 2" spacer lift, what are your fender height measurements? I have more rake than I would like and want to make sure my fronts were installed properly. Any rear spring options besides SAW coils? I have been looking at Wheeler T13. Thoughts?
Here is mine with SAW coils. Not sure if you have any better option for coils if you want to minimize rake, I’m really happy with mine both in lift height and ride quality. They have definitely settled a bit, I’ve had them on for about 20k miles. 37 3/4” up front and a hair over 39” in the rear. Sorry I can’t get that picture to flip over haha but you get the idea.
Just the Toytec lift, no upgrades to anything. I'm at 37" from ground to fender. I also have the C4 Fabrication Lo Pro Bumper with a lightbar and Smittybilt X2O winch. Definitely sat higher before that was on.
I'm about 2" more in the rear (with the Toytec lift) than the front but only because I have a low pro front bumper, winch, led bar, etc.
I'm upgrading the suspension so guess it's a moot point but hope that helps.
Ugh, the only way to accurately measure your lift across vehicles is from hub center fender, otherwise the tires skew your numbers.
on the non pro models, this is roughly 20" in front and 21" rear. on the pro its 20.5" in front and 21" rear. If you have a 2" spacer lift, you should have 22.5" hub center to fender up front.
What are your numbers?
I have tall tires so yes, don’t use those to compare overall lift to yours OP. But measuring front and rear the same way from the street I have 1 1/4” of rake which seems to be more of your concern.
Fronts measure 22.25" (22" on driver side)
Rears measure 24.25"
So based on the numbers you provided, it looks like I am getting a .25-.5" sag up front, presumably from the front bumper and roof rack weight.
More of a surprise is how did I get 3.25" of lift on sway a way coils??
This looks great. ~1" of rake is the ideal look IMO. Every time I see this color, it makes me wish I had got one. So good.
My icon coils give more than a 2 " lift as well. My guess is that the specified inches is not the lift inshes, but rather the leght of the coil compared to stock.
Yup, I have Icon rear 2” springs and it is more like 2.5 “ of lift. This is on 6112/5160 combo front set at 2.5” of lift. Tires are Falken wildpeak at3w 285 70/17 on 17x8.5 SCS RAY10
starting at the rear ground to fender 40” with Icon 2” rear springs
Center hub to fender is close to 25” it looks like 24 but I was holding measuring tape with one hand.
Front is about 38” ground to fender
Center hub to fender in front is about 23”
Top of front tire to fender is just under 7”
Top rear tire to fender is about 8”
I added the 2” icon springs knowing they would give me 2” rake. I chose them over 1.5” SAW coils because I knew I will be adding a rear CBI bumper and the added weight will even out the lift.
See almost stock rake until my rear bumper arrives.
Jhunt
