Fiberglass fenders, any pics?
Happysmiley
Trying to decide on fenders for my 08.
Stuck between glassworks and perry's fab n fiber.
Only pics I've seen online of the glassworks ones are of a black 2wd LT runner but the side pics where the fenders flow into the door are hard to see.
Perry's Fab n fiber ones look good on their site, of course, but seeing how fiberglass fenders never seem to come out in a consistant shape, I was wondering if anyone has mounted a set.
Fiberwerx ones make me want to take my own life.
Thanks, did some searching and checked some threads over there. I'm tempted to try mod my stock fenders and quarter panels
Trimming my fenders looks like it just might work, room for 35's at full compression, this was pretty easy. Jig saw, tape, angle grinder with a flap disk, cutting slow...
Hopefully it will all work out and I'll have a sleeper long travel runner thanks to the stock deep backspaced wheels.
FenderChop009.jpg~original
FenderChop010.jpg~original
FenderChop011.jpg~original
FenderChop012.jpg~original
FenderChop013.jpg~original
FenderChop017.jpg~original
FenderChop016.jpg~original
FenderChop019.jpg~original
Wow! That looks way better than the fiberglass fenders I think!
A :beer: for you for having much bigger balls than I do to try something like this.
Holy cow! We need a couple more pics of the finished product! That actually looks really good, can't believe no other members here or 120 have trimmed that much. I always assumed it would be more difficult and look bad.
The members here (and 120) were trying to get bushwhacker to make some cut out fender flares, and I also figured the reason they hadn't done it was because you wouldn't be able to cut much or do it clean. You've clearly showed that I am wrong.
I'd be interested in some close up shots of the fender post cut with the flare rmoved. I am curious how it looks/strong it is after you cut them.
I'll snap a pic of the cut metal fender when I do the other side.
I cut 3 inches out of the front because i'm running a 3.5 inch over a arm kit, but you don't have to cut that much. I think this mod would be perfect for a 2 inch over kit.
After some initial sniffing around the rear, I don't think the same mod can be performed easily because of the way the flare holds the door seal at the outer edge.
I mean sure, it can be done, but i don't want to start cutting structural body metal away and welding patches over the holes. No fun, not pretty, and sure to crack later. Who's a negative nancy? I am.
Pic of cut metal fender, no flare.
I cut these bolted on the truck so they are held stable, the plastic flares I cut off the truck. Jig saw and tape the edge thats not getting cut off so you don't scratch up the paint, gonna finish it with some plastic molding trim. Probably just going to run 8" 4.5 backspace wheels and Perry's Fab n Fiber fenders because of clearance issues and wideness..
Cutfender.jpg~original
Yes custom kit I made, 3.5" over, 13" travel. Should have just done a 2" over kit and bought a 4wd. Next time.
ArmsFinal.jpg~original
Also, some videos of that suspension in the desert are much needed. That's an awesome setup. Wish I could fab like that...
Thanks,
Back on its feet, giant front wheel wells look pretty silly with the stock tires so I ordered wheels and tires and will hopefully get them on friday. We'll see how much 35's fill them out and stick out on the sides, then go from there on the final plan for wheel coverage and rear supension.
Onallfours001.jpg~original
Onallfours007.jpg~original
Onallfours008.jpg~original
