Finally done: lift and tires!
ARK_SWAMP_RIDER
EDIT: I ended up getting rid of these tires after about 20k miles. They became very loud (for an AT tire) and traction was horrible. It was to the point I didn't feel safe driving in rain, it felt almost as if you were driving on ice. I had approx 60-70% tread left when I replaced them. Despite many positive review, I would not recommend these tires.
First and foremost, this could be lengthy, so bear with me, or scroll down for pics. I have to give thanks where it is due. There were a ton of people who helped me with my decisions, and I thank each and every one of you. You guys are great, and thanks to you I'm very pleased with the outcome. I have to give a special thanks to member 12guns. We met over the forums, and he helped me with the install.
Setup: 2003 T4R Limited, added FJ Cruiser front springs and also a Toytec 1/2" topout spacer. I have the rear air system, so I wasn't able to lift the rear. I was going for a level look, didn't care about much else. After reading CJ3FLYR's thread on the 255/75/17's, I decided to give them a try. I read a ton of reviews online, and finally decided on the Hankook DynaPro ATM RF10's. I ended up getting all five. The spare fit fine, and clearance with the lift is good. I have probably 1/4" between the tire and fender liner on the front with the wheels fully turned.
Results: I ended up with 1.5" of lift on the front with the springs and spacer. My total height is just over 3" higher after lift and tires. It makes a huge difference when driving, you can definitely notice it. And here's where I'm impressed: it rides much better than stock. The front glides over bumps, much smoother than before (due to the FJ springs). I really wish I could have added FJC rear springs, because you can still feel the bumps in the rear. I've not found a single negative with this setup yet. I did tons of research, asked way to many questions, and so I should be happy. I've had lifted rigs before, and none of them rode as good as stock. The T4R is better, and looks amazing, so it's a win-win situation. The tires are pretty quite, smooth, and responsive. I don't have much time on them, so I'll post an update later. The biggest factor (other than great reviews) was that I got a set of 5 for almost the same price as 4 Revo's (which is what I originally wanted).
Important install note: on the 4runner, there is a difference between the left and right coils. The left coil is slightly longer to offset the weight of the gas tank, battery, etc. which are located on that side. We didn't think of this, and as luck would have it, we put them on the wrong sides. I had 2" on the passenger side, 1.25" on the drivers side of lift. So, we pulled them, sure enough they were wrong. We swapped sides, now all is well. No one mentioned this before the install, and it didn't even cross our minds. So, be aware of this, as it will really ruin the excitement when you realize you get to tear it apart again.
Install: really wasn't as bad as I figured. I had a great helper, but the overall process was easy. Compressing the springs was a huge fear, but with an impact it was a piece of cake. The first side took 3 hours, second took just over an hour. When we redid the install to correct the issue, we had it done in 2 hours. Here are a few write-ups I had saved and referred to for the install:
http://www.toyteclifts.com/images/stories/pdf_files/05install2.pdf
2007 Toyota 4Runner Sport Edition Lift
http://www.top4runners.com/ja/2007/lift/KT09115BK.pdf
Daystar (Spacer) installation on 4Runner with XREAS - Toyota 120 Platforms Forum
So, without further delay, here are the pics.
Before:
BeforePics1.jpg~original
BeforePics2.jpg~original
After the lift, but before the new tires (stock 265/65/17 Bridgestones pictured):
AfterLiftBeforeTires12.jpg~original
AfterLiftBeforeTires10.jpg~original
After the lift and new 255/75/17 DynaPro ATMs:
AfterLiftTires11.jpg~original
AfterLiftTires9.jpg~original
AfterLiftTires6.jpg~original
Compared to stock T4R:
AfterLiftTires2.jpg~original
And close up of the tires:
AfterLiftTires1.jpg~original
[/QUOTE]
WOW...your 4runner looks awesome!....those tires are NICE!....:bravo: congrats!.....
I am very jelous now!......:rockthrow: j/k
Turned out nice! Love the tires. I'm getting new tires this week and can't decide which ones or what size...let us know what you MPG does over the next few days. Can't wait to see it in person!
Thanks everyone! As for gas mileage, right now the dash readout is at about 18.9 after 60 miles on this tank. Stock, it usually was lower, closer to 18. It's always been wrong by about 2mpg, so once I get a tank ran through I'll let you know how it goes.
Looks great! That amount of lift with those tires looks just right for my tastes... It's like it should've been delivered from Toyota:D I have yet to find someone who used FJ springs that doesn't prefer them to OE. I know they aren't coilovers but what a great, cheap upgrade:bigok: I glad you're happy. I know you put tremendous effort into making the choice that was good for you, sounds like you got it.
Looks Great! My lift is on the way! How do you like your tires?
Not sure who you're asking about the tires. I love the on road capabilities of them, won't be testing them off road for a while, but will post an update. As far as the 255/75/17, it's SO close you'll have doubts, but they fit. CJ3FLYR sold me on this size (and the FJ springs), and I'm very pleased. They fit just right, and shouldn't effect my gas mileage.
Thanks Chris, I appreciate your help along the way. Every lifted truck I had rode like crap or I ran into issues. So, I took my time and researched every aspect of the lift (um, well other than which side the springs go on...) and knew it was what I wanted. In the end, couldn't be happier. You were right, the FJ coils are a major upgrade. Best of all, they were free. Best thing I never spent money on!
Forgot to ask...any loss of power w/ the taller 255 tires?
I'm reading about others getting BETTER mpg w/ these taller skinnier tires...
Seems like it would go down slightly, but I guess I'm wrong! I'm ordering tires this week and trying to decide!
I guess there is some loss of power, but not much. I've not really noticed it, but also haven't really gotten on it. I'll hopefully know something on the gas mileage by the end of the week, looks good so far though.
I've not measured actual ground clearance, I just know is ~3" higher than stock. The stock tires only measured 29" tall, whereas the new ones are 32" tall (same psi in both). So, 1.5" from that, and 1.5 from the lift.
Nice!!!
Been following this one as well!
Congrats on the project. I just went out and checked my fronts (apparently the fronts were installed correctly ... 2.5/2.6 respectively in the front w/daystar) I have 3,500 on my Hanooks and they dont look a day over new. Doing many DIY's and Zaino(ing) my rig today and tomorrow...will post the long awaited pics after.
:toilet3: (also potty training my 2.5 yr. old in between DIY's)
Stock. I've got the XREAS, and although it's at 130k miles, it's holding out well. When it goes, I'll be swapping in either KYB GR2's or FJ shocks, probably the KYB's.
