Finally found the damn rattling
Mike415
After lots of time trying to find the rattling coming from my driver door, I have finally found it. It was the door trim! I thought that at first but I was too lazy to get on the ground and actually check it out so I checked through everything inside the door panel that could be rattling and finally decided to check out the trim peice. I just put some peices of rubber band between the parts that touch for now. Now I just need to fix the rattle in the trunk. Anyone think its the motor or if its the broken panel in the trunk?
Hey mike, I was wondering if you mounted 6.5's in the rear doors. I tried this on Friday with some MDF to clear the window and had the pocket on the door panel hitting the wood. So I left them out and only run my fronts and subs on a 4 channel amp. Thanks.
I have 6.5's in the back also. They had to cut some stuff away and one speaker was hitting for a while, but they removed some plastic and got it to fit. If I had known I was going to get a sub I wouldnt have done it though.
