Finally lifted my truck!
Fermn
Member
Finally lifted my 2019 4runner! Decided to keep my OEM Trail wheels and slapped on some 285/70/17 Bf Goodrich KO2’s (no spacer).
I’m running a full Dobinson set up including UCA’s thanks to Mike !
I’m really happy with the set up and the truck rides so much better. My only complaint is that my steering wheel is off centered so I took it back but they said I should drive the truck about 300 for the suspension to set in and bring it back to double check everything and at that point they’ll fix it the steering wheel so we will see.
Awesome looking 4R! I have the same truck as yours and want to do the exact same lift. Can u share the specifics of the lift and where did u take it for the install. I live in Ft. Lauderdale so it’s easy to get down to MIA.
Thanks ! I will PM you the details in a moment.
When you have a moment, can you post a couple more pictures of the wheels w/tires from some different front and 1/4 angles? To see how these are fitting please! Love it!
I will tomorrow when I get a chance. They fit the same as before because I’m not using any spacers. Tires look a tad wider but that’s about it. They’re still tucked in the wheel well
I’ll be doing the same once my Dobinsons arrives! How much did the wheels move into the wheel wells? I’ve got a set of 1.25” Spidertrax spacers but I’m back and forth if I want to run them or not
Mm not much. They’re still pretty tucked in. I think spacers look awesome but I’m not willing to do BMC just to run them.
Did you go C or E load? I personally would stay away from the spacers. Looks and works great without and the 285 fills the wells nicely.
Damn that looks so good. It's tempting me haha.
how much of a lift do you have front and rear? Check your CV angle / boots to ensure you dont have crazy rubbing.
Bunkstaff
