Fire extinguisher mount
4thgenblake
I saw this once, never to be seen again or at least not with my patience. That post is long buried by now.
Anywho I managed to pick up a small fire extinguisher travel size let's say, and remember coming across a member who actually made a mount for it. I like the usefulness of having it when or if I need it in the rig. So who's done it? Wanna show me the mount? [emoji3]
[MENTION=66389]BlackWorksInc[/MENTION] thanks, but after reading through this thread seemed to be more for informational purposes only and personal experiences.
I saw a member mount it in the cargo area alongside a panel where the storage compartments are. I liked that idea, so maybe I'll find out exactly what was used or I'll just think a little and come up with something
I just used the mount that came with it and mounted it on the tool compartment. 1st page of my build.
I mounted mine on the panel that covers the jack. I'll get you a pic this afternoon.
Don't have the mount, kind of secretly took it from work so it came without one. But we have so much extra crap that it'll go easily go unnoticed. That's just the pros of working in a construction warehouse with extra amounts of anything and everything lol.
Off topic but ya... Thanks
Lol that's a bit more difficult. I would make a bracket with a base to support it a small collar and then like a velcro strap. I'm no good at modeling so you'll jus have to picture it.
Cool. Now note that my extinguisher is without the mount that usually comes with one. And it's pretty heavy but very decent size.. Lemme see if I got a pic
When I say heavy I'm pertaining to a mount being able to support it well enough that I won't have to worry while off-roading. But also an quickly accessible breakaway type thing
With what bracket?
http://www.amazon.com/gp/product/B001U0PFIQ?psc=1&redirect=true&ref_=oh_aui_search_detailpage
It's a cheap amazon mount. It's for that size fire extinguisher but it makes no mention of the brand that I have, so it's not quite right.
It's actually been giving me quite a bit of trouble. The retaining strap just doesn't quite work with my fire extinguisher so occasionally on a sharp turn the strap pops open and then rattles back there driving me insane until I get a chance to stop and lock it back down.
I'm going to be fiddling with it this weekend again. It's a good design in theory as it allows for quick access, but it's just not quite right.
Hey guys... Took a screenshot of this a while ago when I was perusing around on Amazon to find an extinguisher mount that looked beefy and clean that could take a beating off-road. If I'm not mistaken, you secure the extinguisher to this unit with one of those silver buckle with the flathead or Phillips screw for tightening and you are then able to use the red "PULL" for quick release in an emergency situation. I agree that the jack and spare tire kit cover (I have a 4th gen) appear to be the best mounting point (IF you can secure it with out the little door popping off when you're on the trails..... [emoji16])
That's another issue I run into on occasion ^^^. The tabs on the cover for my jack are pretty worn from the PO. If the tabs were in better shape I'm pretty confident that it wouldn't be an issue though. I've had mine mounted like that for at least 6 months now and only had the mount and the cover jump off once.
That is a pretty slick looking mount though!
Yes I saw that. And it is by far the best looking one out there and for the money looks like it'll do the job. Do let us know if u buy it and use it. I want to get away from the hose clamps though but still have the fast release. I'm actually looking at this one. I like the double straps too
519ef1ff4f6a93ca9c81d41687fac91b.jpg~original
This is the one I have, if I actually need it the clamps let go VERY easily.
Here's where I have it mounted. I did have to put a secondary latch in to keep the door attached to the cubby. The weight of the fire extinguisher kept knocking it out.
IMG_20151226_165405.jpg~original
Awesome. So you like it then. Cause I just ordered it lol. But you have what seems to be the full size extinguisher, while mine is the 2.5 model.. 10 lbs. ish
So hopefully the panel doesn't fall off, but looks like u got the necessities goin on [emoji1362]
The mount itself works great, other than the door falling off I haven't had any issues.
This is the fire extinguisher I have.
http://www.amazon.com/gp/product/B00F5CK9X6?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
After reading through this thread the only thing I can figure is it would be better to get it the head with a 3lb missile traveling in excess of 50 mph than to burn up. I'm not sure those plastic panels let alone a "removable" one would hold much of anything in a serious sudden stop (crash) and/or rollover. I keep mine strapped down to two of the cargo tiedowns a cloth cradle beneath and feel I can reach it pretty quick. I've though of making a bracket that would mount under the left rear tiedown.
As promised. I mounted mine pretty low so the panel isn't carrying all the weight. The rag is a shim since the extinguished is an amerex and the mount is a kidde. It's not perfect but it's functional.
That's why I have a latch on the panel, so it doesn't fly off. It went from falling off every bump, to never moving, so I'm not too concerned. Plus I couldn't go any lower because my hi-lift sits just under it.
Jhunt
