first gen fuel gauge
MacGyver1979
My 87 fuel gauge shows full when I top it off then soon pegs out under E, is this common? anyone have a fix for it.
I dont expect it to work perfectly, just as it should.
I have found the "float" on the sender to be an issue some times .. also , there is a check for the gauge in the OE manual , I have ran into this a few times
mine quit will its been sitting for several months & wont read anything..... So when I pull the tank to figure out the problem, Im going to cut an access hole through the floor & make a cover plate.... That way if I ever have an issue again all I have to do is remove the plate.. (much easier than dropping the tank)
I've got the same issue, goes empty when I have about 2/3rd of a tank left. Annoying. If you end up fixing it let us know how it goes.
If the sending unit is not too far gone, you can take it apart and clean the winding with some electrical contact cleaner and a tooth brush.
Worked for me several times.
That does not get you to the fuel gauge sender, that access is only for the fuel pump, the sender is 11" further back.
HUH! I learned something new today! Didn't realize that door does not get to the sending unit! I always thought you could access it from there.
I don't have a 1st gen 4R, but an Xtra Cab truck, and had to drop the tank for this very same issue. Actually, I loosened the bed bolts and just pushed the pass. side up enough to get the sending unit out. Was much easier than trying to drop a full tank of fuel.
Also, IIRC, there are two types of sending units, one for the SR5 and one for the non-SR5, I think its because of the SR5 low fuel light, but I'm not positive about this one. Its been 20+ years since I replaced it on my truck.
I did get a picture today from a friend at Toyota. She got the correct on in (3 wire with low fuel light) today and it will be here in less than a week.
Now to find that darn cable under the pass seat...eBay has them for 80-100...I'm wayyyyy to cheap for that..
Says the guy who bought two extra trucks (plural!) so he could garage his pretty ones (plural!) for the winter.
Funny you say that, because I just gave up and ordered the eBay one.
Before I moved to Ohio, I did not have to get extra trucks. But here, when all the stuff under my truck that I sell is made from metal...I had to make a choice. So I decided I would do what I can to keep them from rusting, until we upgrade to the 6th gen...
Or....what if  makes a new 4x4 that can get 53 mpg and run factory 37s.....
Southshore
