First Post and a few questions..........
rrp0968
HI everyone............
My name is Ron from South Louisiana. I have just purchased a new 2008 4Runner Limited. Love it so far.
Have a few questions..........
I have done a search everywhere looking for this info........
My 4Runner has the XReas Suspsnsion..........just what does XReas stand for..............Toyota had to have something in mind when they came up with it.
As far as the 12V power ports go............is there a mod to make them hot all the time. On my 01 Tundra, you could remove a relay under the hood and install a jumper to make them stay hot.
Thanks in Advance
RRP
Well....I found a post here with a how to on the power outlet mod..............refined my search a bit.
http://www.toyota-4runner.org/showthread.php?threadid=1076
Shocks are linked in an "X" shape.
Thai said:
There's been some questions about the XREAS system. So, below is my description of the system and it's purpose:
XREAS shocks are MONO-tube shocks and thus, are high-pressured shocks. They should (in theory) last the life of your 4runner or for a very long time. They are more efficient in damping the ride, but they are significantly firmer than regular low-pressure twin-tube shocks (found on non-XREAS 4runners).
XREAS shocks are cross-linked: left front shock to right rear shock; right front shock to left rear shock. Thus, "X-shaped."
XREAS is a closed-circuit system; thus, you cannot replace just one shock. You also need to replace the other shock that it is connected to.
XREAS is very good for cornering on-road (it's MAIN purpose)...helps to reduce body roll. As you take a corner, the 4runner will rock towards the outside. XREAS senses this and hydraulically pumps more fluid to the outside shocks (by drawing from the inside shocks) in an X-pattern. This helps firm up the outside shocks, and softening the inside shocks. Thus, you have less body roll because the outside shocks are pushing against the body lean.
In off-roading?? XREAS probably won't do much in off-roading. However, because it has MONOtube shocks (high-pressure, quicker reacting), XREAS suspension is more efficient in controlling your 4Runner body motions over bad terrain. Since monotubes are more efficient, you have less chance of shock fading/overheating. HOWEVER, monotubes are more fragile than twin-tube shocks...therefore, if a rock hits it, then it will have a higher chance of damage.
As for lifting your 4runner with the XREAS system, i believe that you do need to replace the shocks if you do a high lift. But this also applies to regular non-XREAS shocks. Remember that when you lift your 4runner, you need longer shocks to cope with the increase articulation. Shocks should NEVER be the limiting factor in wheel articulation...that is what anti-roll bars, bumpstops, and rod links are for.
Hope this helps.
