I recently purchased a '91 4R (acutally it's a Hilux Surf bought here in Japan). Just over a year ago, the A/C system was recharged and the receiver/dryer replaced. Here is the problem:
If the fan is in any other position except off, the compressor clutch engages and it blows cold air with or without the A/C button depressed.
More specifically:
With the fan running, pressing the A/C button (i.e. A/C control switch in the on position) will cause the motor to idle higher, the green light will come on and obviously the compressor turns. Air blows cold.
With the fan running, depressing the button (i.e. A/C control in the off position) will cause the idle to drop, green light turns off but the compressor still turns. Air blows cold.
Fan switch off causes the compressor clutch to disengage and the green light on the A/C control switch goes out (regardless of button position). Obviously no air at all is blowing.
I'm thinking it could be a compressor coil issue as the switch inside the cab actually still kicks the idle up when activated and the green light comes on so it seems to at least partially work as advertised.
I took the dash apart hoping to be able to remove and test just the A/C control switch but of course it's part of the whole environmental control assembly which appears to be a complete pain in the ass to remove as a unit.
It's not a huge problem, but as the cooler weather is approaching I like to have the fan running blowing external, ambient air instead of running the compressor all the time.
Any thoughts or suggestions?
R/
Konish
More specifically:
R/
Konish
