justgio928
In October I was able to snatch a great deal on two 4runners. I got an 88 DLX and an 87 SR5 together for $900. The 88 DLX is now my daily driver and is doing great just been tweaking a little here and there to try and get more power from it.
The real issue I'm having is with the 87. The man was originally planning on selling the 87 for $1200 by itself but when he went to show it to me it started rough and had a knocking. Assuming that it really was an overnight development what could have gone wrong?!
I have done compression tests on all 4 cylinders and by adding a little oil they all came up to 160 or 170. So I'm assuming the valves and pistons are functioning at least that well. Yes I know that means the rings are bad.
It is running on two cylinders currently. As I drove it home, it would intermittently pick up and accelerate hard and fast then as suddenly as it began it would bog down again and I couldn't get past 2nd gear without killing it.
When I pull the boots on the 2nd and 4th cylinders when the engine is idling, nothing happens. When I pull the plugs after revving the engine a bit the plugs for 2,4 cylinders are wet. If I pull 1 or 3 boots the engine kills.
I took the wireset and used it on my 88 for a day and it ran fine.
Any suggestions or experience in the matter would be greatly appreciated!
Justin
I can add pictures and such as necessary.
Justin
