FJ Cruiser Rear Springs & Spacer lift installed
Re: Re: Re: Re: FJ Cruiser Rear Springs & Spacer lift installed
FT5117 said:
FOLLOW UP "Report":
New CJ3flyer commercial:
Front coilovers: $35
Rear shocks/coils: $50
Bushings/Endlinks: $50
SUV w/ sports car handling: Priceless
:bigok: :lmao: Awesome! I'm on the run now, will reply to PM later, Thank-you.
:cheers:
Falls said:
I had asked a question a long time ago about why I could not just put different/slightly longer 1-2" OME springs on with my Xreas , but never got an answer.
Why the heavier spring rate ? I would think it would effect the ride , correct ?
I have wondered that too. I understand the length of shock travel could become an issue. I would think 883's in the front and Airlift and/or FJC springs in the back would be ok.
I think the effectiveness of the XREAS would decrease a bit unless you somehow added some fluid. At rest, with the T4R slightly lifted, there might not be enough fluid. E.g.- In a right turn the front shock extends. That fluid immediately goes to the left rear. Because the left rear started from a position of greater extension would the fluid supplied by the front right be enough? I have no clue. It seems to me the worst case with a mild spring lift would involve some loss of effectiveness of the XREAS. Now, any loss of effectiveness would probably be more than compensated for by the extra spring stiffness. I wish I had XREAS, I'd do it, I ain't skeeeered:D I come to that conclusion based on studying pretty pictures of XREAS, not any real experience so take it with a grain of salt:D
:cheers:
I may call Wheelers today and just pick their brain about OME and stock shocks . People run a 2/1 with out shock issues , yes it does limit it I know.
Day 2 FOLLOW UP Report:
As mentioned earlier, upgrading the suspension has been a three step process. Short after installing the front FJ coilovers, I noticed an instant improvement in handling, but not enough to stop the major body roll from turning into slightly angled driveways or parking lot entrances (90 degree / right turn). I'd always forget I was driving an SUV because I switch between vehicles during the week. Worse was when a friend drive my T4R... she's not used to beemers not SUVs... made a sharp turn into the parking lot entrance and the 5 of us felt like we were flying all over the place (seatbelted). Well this morning, I drove into the same parking lot and went "oh crap" because I forgot to slow down... the entire truck body started to act like it was about to thrash around but the bushings/endlinks kicked in and started dampening the roll and things instantly evened out... resulting in minimal roll. Two words: ItWasAn AmazingExperience. My T4R drives like a car, does yours? lol.
For those of you concerned with diminished offroad capabilities... you need not worry, you're supposed to disconnect (unbolt endlinks) the stabilizer bars before every offroad outting, anyway.
btw, CJ3Flyr, would you mind adding this info to the first post of your other thread, it'll help save people a lot of time.
http://www.toyota-4runner.org/showthread.php?s=&threadid=34115
http://www.neverenoughauto.com/index.php
4Runner V8 2WD parts:
Prothane Greasable Universal Bushings
21mm 19-1164-BL
30mm 19-1186-BL
Most important T4R thread, ever.
I received a set of FJ Cruiser springs in the mail today...I'll install them at the same time I install the spacer lift, if that ever gets sorted out...
CJ3Flyr and FT5117:
How can I tell which end is the top end of the FJC Springs?
One end of the springs tapers flat and the other does not.
Also, should I inspect the the FJC Springs in detail for any particular types of damage, wear or use before install? Anything particular that you can think of that I should look out for?
Thanks.
I'm planning to swap the XREAS in my 2004 4Runner Limited with the B1500s and FJ springs. Do you know the parts numbers of the FJ springs? Any specific year? OEM website for purchase? Thanks.
Cpn2mss
