1000MPH
Senior Member
I've had my TE for almost 8k miles now. Coming back from a 50 mi drive and my TPMS comes on. I pull over and find my RF is at 24psi. There's no visible or audible clues so I drive a mile or so the the nearest gas station and check again. Still at 24 psi so I risk limping home (the air comp was out of order). Once home I check and it's at 22 psi and there is an audible leak at the rim. I sprayed it with water and it's leaking about 1/4 the way around, does not appear to be from the tire and no visible tire or rim damage.
I did a search for leaks at the rim and most answers were corrosion or poorly seated beads.
What are my chances the dealer will fix this under warranty? (what's so funny?)
