Fluid Change Questions *HIGH MILEAGE*
McLoven1t562
Hey Folks, so I've gone through a lot of vehicles in my years and never really had most long enough for various fluid changes (except like coolant and oil)
My 96 SR5 Auto has 328k on it and I've owned it for the last like 30k miles....So far I've only done oil changes, coolant, brake and power steering.
Biggest question is should I be doing (and how often) fluid changes on things like the differential, transmission, n things of that nature?
Since I'm the 3rd owner I have zero idea if/when any of that ever got done so i'd love to hear some feedback.
Since you don't know the history and you are already in the mileage window for differential and transfer case fluids since you picked it up, I would change those out.
and... since you don't know the history, and you have a senior citizen on your hands, changing tranny fluid is a dicey proposition. I might be worth taking a sample to assess condition but if it hasn't been changed in a long time or at all, changing it now could cause problems.
Diffs/transfer case should be done every 15-30K miles. I agree with the above regarding transmission. If it were me personally, I'd take my chances at look at the color of the fluid on the dipstick and see what it looks like. If it's not horrible looking then I'd go ahead and do a drain and fill.
Sent from my SM-T220 using Tapatalk
Whoa!
I do everything at 90k and I am done until next 90k. All mine go 285k+ and no problem what do ever expect my driving. I worked for Toyota and you don't have to do all that so often. You can do practically nothing and get hundreds of thousands of miles anyway. Synthetic does really wear out or contaminate with water easily anyway
I believe with Toyota's older models you could extend with the fluid change compared with new ones. I guess due to the materials and how it was engineered. I suggest that you stick with 30miles
Agreed. Defense is the best offense, or something like that :)
charlesz
