Fluid Film Applicator
Hey All!
Just got a chance to apply Fluid Film to the inside of my 4Runners
frame. She is a 2002 and felt it was cheep insurance as I am in the
rust belt of Upstate, NY............
I wanted to give you folks an overview of an applicator I purchased on
Ebay to do this:
1 ~ Fluid Film 360* Spray Extension Wand For Aerosol Can Free Applicator Brush | eBay
This spray nozzle worked like a charm! I was skeptical of spending the money
but tested it and was amazed at how well it works. I used just about 4 spray
cans of Fluid Film to coat the inside of my frame which at $10+ @ can it isn't
cheep but good insurance for around these parts. The cap of the applicator
does not attach permanently to the nozzle but you put the wand ( 24" ) on
and off quite often as you need to fish it in many points of the frame so not
a problem IMO. I drew the flexible plastic extension when applying the film
as drawing it has more control and I wanted to go slow to insure the best
possible coat of this rust inhibitor as you cannot see inside the frame. FYI
The test I spoke of showed that the 360 degree applicator has about 12" of
possible spray distance and inside the frame I expect each point ( 5 )spraying
has a spread of film 3" - 6" wide.
LMS
Their products work great. I have that and the spray gun you use with an air compressor. If you plan on doing this more than once if get the spray gun but this applicator works well.
Sent from my SM-G960U1 using Tapatalk
Trey99ek,
Agreed and wanted to buy one, but only have a home garage and the applicator that uses air pressure with the Fluid Film being drawn up into the applicator wand looks like it could be messy? What is your experience with using it and I'm thinking I would want to borrow a garage lift with that gun?
Is this what you have used?
Fluid Film & Woolwax "PRO" Undercoating Spray Gun with 3 Qt. Bottles & 2 wands 661799636308 | eBay
Trey99ek,
I have the Woolwax gun and 3 Qt bottles.. Works great if the fluid if is slightly warmed up flows better.. I mostly clean the surfaces really good and paint first before filming so you can see if something is changing underneath the paint..
