I have the V8, which has the additional transmission cooler attached to the front of the radiator. There are two lines that go into it: One on top, one on bottom. I'm not sure which one is the delivery line, and which one is the return line? I'm not completely convinced we can't flush the system from these two lines alone. So, I was thinking: What about those brake-bleeding machines that pulls the brake fluid through the lines via suction? What if you hook up a brake bleeding gadget to the delivery line of the cooler, and placed the return line in a bucket of new transmission fluid, and then pulled the new through the system with the suction force of the brake bleeder? Just pull it until the new stuff starts to come through the line? Doesn't this seem to make sense? I'm sure you probalby have to still drain n' fill the pan though?
Mity Vac: aren't those gadgets called mityvacs?
Like this: http://www.sears.com/shc/s/p_10153_12605_00947647000P
