PhdNPrerunners
Well as much as I am really going to regret this I have my 2 focal amps up for sale. If you know about car audio then you know focal is high end stuff. The only reason I am getting rid of my amps is because I need to get a macbook pro for school. I have had the amps for about 6 months and I bought them brand new from Amazon. These amps are in immaculate condition, they were installed and removed professionally. Here are the specs on the solid 1 red amp
Focal Solid 1 Red
* mono subwoofer amplifier
* 300 watts RMS x 1 at 4 ohms (470 watts RMS x 1 at 2 ohms)
* CEA-2006 compliant
* variable low-pass filter filter (50-150 Hz, 12 dB/octave)
* subsonic filter (35 Hz, 24 dB/oct)
* variable bass boost (0-9 dB at 50 Hz)
* wired remote level control included
* Class-AB amplifier design
* frequency response: 10-150 Hz
* preamp- and speaker-level inputs
* preamp outputs
* 4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
* fuse rating: 25A x 2
* 11-13/16"W x 2"H x 7-7/8"D
* warranty: 1 year
Focal FP 2.150
* Power Series 2-Channel Class A/B Car Amplifier
* RMS Power Rating (13.8V):
o 4 ohms: 150 watts x 2 chan.
o 2 ohms: 200 watts x 2 chan.
o Bridged, 4 ohms: 400 watts x 1 chan.
* Pulse Width Modulated MOSFET power supply
* LED power (green) and protect (red) indicators
* Tri-mode speaker capability
* 2/1 channel operation
* Preamp RCA outputs to daisy chain multiple amps
* 7-Way System Protection circuitry (DC offset, short-circuit, continuous power, thermal overload, soft clipping, over voltage, polarity error)
* Heavy duty aluminum alloy heatsink for extreme heat dissipation
* Gold-plated RCA level inputs
* Gold-plated screw terminals
* Input sensitivity:
o Level: 200mV-5V
* Variable high-pass filter (50-150 Hz, 12 dB/octave)
* Variable low-pass filter (50-150 Hz, 12 dB/octave)
* Damping factor: >500 @ 4 Ohms
* CEA-2006 compliant amplifier
* Frequency response: 10-35,000 Hz
* Dimensions: 13-3/4"L x 11"W x 2"H
I paid over $1500 for these amps new. Im looking to get $300 for the solid 1 and $500 for the fp 2.150 or trade for a unibody macbook pro 15" or bigger. Let me know if you are interested. Thanks
Focal Solid 1 Red
* preamp outputs
* warranty: 1 year
Focal FP 2.150
o Level: 200mV-5V
