Fog Light Bulbs
bowen873
I've been searching, but haven't found a clear answer. I was planning on doing the H11 to H9 conversion for my low beams. What bulb sizes/watts are people using in their fog lights? I'm not ready to install the HID kit yet.
I highly recommend the Hoen Endurance Yellow fogs. They look nice and provide good visibility.
IMG_0405.jpg~original
so has anyone put 9005's in the 06+ fogs?
i have winjet yellow fog housings and want more light out of them. they are already brighter then stock do to not having the extra reflector in the housing. if i was to go with a brighter bulb in 9006 i would have more of a white light. so end goal is more light but not trying to change the kelvin
Ordered 9005's. Next thought is if I also swap to h9 for headlight is that a bit much or should I stick with one
I have installed the H9 in the headlights and I'm glad I did so much brighter and whiter. My next step is to do the fogs. Post a picture when you put them in will ya?
well i went to change out the bulbs and one of my winjet fogs has a broken screw on the part that holds the bulbs so i need to get new fogs. dont know if the company is going to cover it or not
fixed my fog housing today. i ended up getting the cheapest 9005 and its only 60w but here are pictures to compare. i will not be able to give opinion unil tomorrow
drivers side is new 60w 9005 vs 55w 9006 passenger
truck off
5P8A3892_zps2778d0b3.jpg~original
truck on
5P8A3894_zpsf4ba48a2.jpg~original
9005 or 9006
Kevin, On my monitor, I see no difference between the bulbs. Is the new 9005 brighter? Is it too white, or stay yellow with the Winjet lens? I see there are 65w yellow 9005 bulbs with good reviews. I wonder how that would look with the yellow lens of the Winjet.
Thanks!
Kevin, On my monitor, I see no difference between the bulbs. Is the new 9005 brighter? It is too white, or stay yellow with the Winjet lens? I see there are 65w yellow 9005 bulbs with good reviews. I wonder how that would look with the yellow lens of the Winjet.
Thanks!
i only went from a 55w to a 60w. light output has changed some but the un capped bulb does make it shine different
I went with some 3000K Yellow HIDS + lamin-x yellow films for the fog lights, it makes for a very vibrant yellow hue when they're on, love em!
334143_10151324706470914_2104817601_o_zpsac63c4b1.jpg~original
leolediola
