Fog Light Help !!!
Ramsil.TRD
I need some help with my fog light... I want my fog light to blink with the turn signal... And want the DRL always on... Excuse my english but I'm from Dominican Republic...
That's the strangest request ever, but not impossible. You'd have to get the + wire from it and wire it to the turn signal + wire and that should take care of that.
For the DRL,s you'd have to find a wire that's always hot when the car is on (fuse box up front should have at least one) and wire the + wire into that.
Halogen fog light bulbs don't do well with cycling off and on, you would be wise to switch to a non-halogen bulb for this. If it's a high-power bulb you'll need to run a relay on each, if you don't know how to hook up a relay you should probably have someone else doing this project.
I layed over at the Quality Hotel near Las Americas Airport on Sunday, bored and unable to go anywhere, would've liked to have something to work on!
I want the fog light stay on normally... But when the turn signal is on I want the fog to blink...
Ok, that's way different. Not sure you can do that without some really custom wiring done.
You just need a relay on each light. Switched power to the power side of your fog bulb, and ground through the relay. When the blinker circuit activates the relay, the relay would take away the ground for the fog bulb. So the fog light would be off when the blinker bulb is on. Both fog lights would blink with the hazard flashers.
johnnya
