Fog light issue please help!
zstampe
Alright guys and gals, I have a very puzzling Foglight issue I need help solving the truck is a 2006 sr5 4x4 without drls. I tried doing the Foglight mod and I couldn't get the fogs to turn off, I tried different ways of doing it all with the same results. So I decided to give up on it.
At that point I put it all back to stock and now the fogs won't work at all. I tried swapping the fuse and relay with good ones and the bulbs are also good. Any ideas guys? Please help!!!!
Thanks,
Zach
the first fog light mod, did u get power from another source? once u did the part one, u will need to have the key on the on and then turn the fog on, if that didnt work u might blew a fuse.
any luck at the dealer or did you decide to download the manual? sorry about the lack of responses on here but glad we could help out on the 120.
keep us posted on what you find out.
Check the switch. I made a mistake when I was hooking mine up and it made a burn mark inside the switch causing a bad connection. Took it apart, cleaned it up and it works like new again.
