H HNTMUP New member Apr 19, 2009 #1 Might be the fuse. Both fogs stopped working at the same time. Thoughts? Which fuse supports the fog lights? The "Accessorie" fuse?
Jordan Petry New member Apr 19, 2009 #2 Your brights weren't on when you were looking at the fogs correct? They shut off once the brights are turned on. I thought the same as you once but then realized I had the brights on. Just a thought, :bigok:
H HNTMUP New member Apr 19, 2009 #5 bgmac said: Could be a bad ground Click to expand... How do I check that?
H HNTMUP New member Apr 19, 2009 #7 They are Hella Micro D's mounted in the bumper where the OEM's would have been had there been lights originally.
