Seems from the diagram that the red wire supplies the main power to the unit. The white wire, it says, is for the unit to know when they key is in the ACC or ON position, to force the mirrors open.
daytonaviolet, is the diagram wrong?
I thought this had been posted somewhere in here, but I knew I'd read it in the instructions.
Untitled by Brian Praetorius, on Flickr
You shouldn't need to cut wires.
Looking forward to installing myself. I have a set in the basement ready to install when the weather gets warmer.
Yup, that is what I have. The white wire is part of the harness but not one that you connect via a tap or anything. That is why I was asking where it goes. Either way, DO NOT cut this wire like I did or the mirrors will not function at all!
My passenger mirror completes it's fold two whole seconds before the drivers does. I can confirm that it is NOT a friction issue as I've disassembled the drivers mirror and ran it standalone... still slow.
Thanks for the updated PDF! I did end up figuring things out, it just took a while.![]()
Okay this all makes MUCH more sense now. I'm not at all worried about it and [MENTION=54749]LakeRunr[/MENTION], you're totally right... the mirrors are swinging at the same degrees-per-second and even the sound of the motors are at the same "bzzzzzz" tone. I never realized that the mirrors are set at a different distance/angle.
Been enjoying the folding mirrors!
Yep, both of my mirrors unfold when I unlock the vehicle or press the button on the new mirror switch.
The issue of the fuse blowing only occurs when I physically connect the blue wire off the ECU to the other blue wire off the connector (For lock detection). As soon as I connect the blue wires and turn on power to my vehicle the fuse blows. Locking or unlocking the vehicle isn’t the cause of the fuse blowing.
So right now I don’t have the blue wire off the ECU hooked up at all because that’s what immediately trips my ACC fuse. I’m able to fold the mirrors manually with the switch, and unfold them by unlocking the vehicle or manually with the switch.
My vehicle locks and unlocks like normal, but since I don’t have the blue wire hooked up, my mirrors don’t fold when locked.
Hopefully that makes sense.
Jake
What was your solution here for the passenger mirror closing sooner than the driver? I thought it was the angle is not as much as the driver ?
Is this a setting /problem? I used Rev3
If you want the mirrors to stay folded during unlocking, just follow the option 2
This is not working for me. Pressing the fob lock 6x?
Am I doing it right? Please advise
No, not the fob. It’s referring to the drivers side lock and unlock buttons for the door.
Started this mod today, took longer to take apart the mirrors than I hoped since I have the Meso puddle lights and Suma Mirrors with turn signals, so I had a lot more wires to deal with than stock. The biggest pain in the ass so far was separating the 2 plugs from the stock plug harness, my GOD was that a giant pain in the @$$. I was very frustrated and took a lot of cursing and swearing to get the drivers one apart, I learned a few tricks but I still fought with the passenger one as well. Holy Hell what a pain!
I know hour pain man. it was my first time doing this too and I also spent a lot of time trying to remove those wires.
Drivers side motor already went out. Getting a new one but who knows how long it will take. Had to disable the mirrors by pressing the lock 7x. Honestly I wouldn’t recommend these as they just aren’t made to last. The motors are weak.
