Fox 2.0 rears with OME 2895E
uplusd
I've searched and haven't found any information on this combo. Will the OME 2895E work with the fox 2.0 rears that are rated for 0-1.5" of lift? The other option is the fox 2.0 rears meant for 2-3" of lift. The specs on the 2895E says 2" of lift, however the forum vendor I purchased them from stated they're closer to 1.5" of lift and had me buy the 0-1.5" version of the fox 2.0 rears. Would appreciate some input before I end up putting the wrong spring/shock combo on the rear.
Thanks!
Typically the OME 2895E Coils provide 2'' of lift for a 5th gen 4runner. They are known to provide 1.25'' of lift on a 4th gen 4runner. I believe you're going to need the 2.0 Fox Shocks for 2''-3'' of Lift.
What if I have third row seats? Will that help bring the 2895E down a bit?
I believe those are the same springs that came in my kit. Mine were the Factory 2.5 resi setup. I believe the vendor set me up with the 1.5" shocks as well. I didn't even question it because they are a site sponsor and figured they knew what they were doing. Hopefully everything is ok on mine.
Thanks!
Resurrecting this old thread because I'm looking to do the install on this same set-up tomorrow. Fox 2.0 (0-1.5") rear with the OME 2895e springs. I'm curious what you decided to do and what your thoughts are on the set up. I too, had a site sponsor tell me the shocks have enough travel to cover, but would like to hear from someone with first hand experience on the set up. Thanks in advance.
