Front ABS sensor o-rings
repo
I couldn't find a part number for these and the hardware and auto store ones are too fat. Anyone know where to find some of these o-rings?
That sucks man, hard thing to find. Those are the only places I would know to look. Might could check a motorcycle shop, as well. Search amazon for oring assortment kits. Gotta be some kind of way to find one.
They seem to be USA size 017 or close enough. 11/16 ID × 1/6 CS. Found some at Ace hardware.
Ace is the place!!! Hahaha glad you found some. This is something good to note for future times. I just had mine out and was hoping I wouldn't mess up the o-ring. I used to work at Ace, they are usually pretty clutch.
Good stuff man.
Good stuff man.
They are slightly thicker after I compared them out of the plastic bag so I dunno. I'm going to get some of the 04 Tacoma rear o-rings and see how they compare. The FSM says to replace them every time the sensors are removed but there is no part number for them. I dunno if they are JIS or what. They have a really thin cross section.
I just had both mine out in the front and put them back in with the old orings. Not lights or anything yet. Water is obviously the devil here so we will see. I greased them up pretty well before I put them back in.
Just an update to this discussion.
I ordered 1997-2006 Tacoma rear ABS sensor o-rings. The part number is 96723-19021
The Tacoma o-rings are too big to use on the 3rd gen 4runner front ABS sensor.
seltzernator
