front axle nut help......
rtp2010
New guy here and I just reassembled the front and need to know the torque for the axle nut. Anybody got any help? Thx steve
From the 2006 manual - 4WD:
AH–18 AXLE – FRONT AXLE HUB (for 4WD)
AH
6. INSTALL FRONT AXLE HUB NUT
(a) Install the hub nut.
Torque: 235 N*m (2,396 kgf*cm, 173 ft.*lbf)
(b) Install the adjusting cap and cotter pin.
7. INSTALL FRONT AXLE HUB GREASE CAP
8. INSTALL FRONT DISC
9. INSTALL FRONT DISC BRAKE CALIPER ASSEMBLY
(a) Install the front disc brake caliper assembly with the
2 bolts.
Torque: 123 N*m (1,254 kgf*cm, 91 ft.*lbf)
2WD:
(a) Apply the MP grease to a new O-ring.
(b) Install the new O-ring to the axle hub.
(c) Install the dust cover, axle hub to the steering
knuckle with the 4 bolts.
Torque: 80 N*m (816 kgf*cm, 59 ft.*lbf)
4. INSTALL FRONT WHEEL ADJUSTING NUT
(a) Using SST, install a new adjusting nut.
Torque: 275 N*m (2,804 kgf*cm, 203 ft.*lbf)
SST 09318-12010
