Front Brake Hoses
Phx994Runner
I was noticing this morning when I turn my wheels fully, the rubber brakes hoses up front are cracking. I'm sure they're original. I have a 99 Limited 4x4 - does anyone happen to have the Toyota OEM part number?
I found one on a couple of sites but they have no number and no picture, they're like $67 each - ouch. I see PartsGeek and a couple of others have PBR and Dorman brands for much less - anyone used these?
Also I sometime see a "front" and an "intermediate" - what does that specify exactly?
Thanks.
+1 on the Wheelers, but if you want OEM, they list at $84 each, but can be bought for $60 off the web.
part# (same for both sides):90947-02862
I would say to replace the tube that goes from the line to the caliper:
right: 47314-35330 and lists for $7.96
left: 47316-35250, also $7.96
I changed my front brake hoses when I did my Tundra brake upgrade. I got them for $10 ea. at Napa. They look identical to the OEMs I took off and they had all the correct fittings. If you pay $80+ each for OEM hoses, well... you'll be getting hosed.
Thanks guys - the ones at Wheelers do look impressive.
I found some more "over the counter" ones from vendors like Bendix and Raybestos. I'm currently stock suspension height although will be putting in a set of OME 906's in the coming weeks. Looks like stock rear hose has enough play in it to flex down just a bit.
I'm going give the Raybestos a shot:
Front: BH38986 $8.41/ea 11.5"
Rear: BH380895 $10.38 14.5"
Figure I'll do the rear, too, since it'll need to be bleed - do it once not twice.
I'll do a search, but anything special on the 4Runner to watch out for or special when bleeding?
Thanks for the input.
How-to question ...
So I've got the brake hoses (all three - the "intermediate" is the one longer hose on the rear), a 10mm wrench and DOT3 brake fluid. My question is - what is the process I should follow before I remove the hoses?
Do I need to follow the start of the bleeding procedure by pumping the pedal 40 times with the ignition off to de-pressure the lines? I don't want fluid spurting and gushing out once I loosen the first hose.
Should I then just replace all three and THEN bleed everything, or do the rear first then bleed, or ...?
Lastly, does anyone happen to know what inside diameter (ID) plastic hose I need to fit the bleeder properly?
Haven't done this before, any advice/pointers welcomed - thanks!
Any issue with the aftermarket hoses?
123595d1210084000-es-owners-with-is300-17s-need-some-help-holy-thread-revival-batman.jpg
