Front brakes: help me & learn from me
pdunc63
I'm getting started learning how to work on vehicles more than the usual oil change and spark plug tuneup. Changing the front rotors today was RUDE awakening. Who knew I would need a 2 1/8 inch thin wall socket and torque wrench? No autoparts store had the socket I needed but I found one at the pawn shop and brought it home. That's when I learned that it was the right size for the adjusting nut but the wrong thickness to fit inside the hub housing.
Here's my advice- when you buy the new rotors get the right socket. Better yet, find a buddy who already has the 20 dollar socket and pliers to remove the spring washer. Give yourself some time because you've got to take apart the locking hub and repack some bearings in the process.
Here's my question- after getting the caliper back on it seems like there is way too much resistence when I spin the rotor. What could be causing this? What can I do?
I have to assume that you also replaced the pads. Probably what happened is you didn't open the caliper pistons enough. That should be ok though because the pads will reset themselves once you apply pressure to the brake pedal the first time. Someone please correct me if I'm wrong.
Disc brakes do create some drag on the rotor.
If you can spread the pistons far enough apart to get the new pads in and slide back on the rotor, you should be OK (as long as one of the pistons in the caliper isn't sticking).
That was a good writeup about the pads. I can't stress enough that you have to pump the brakes a few times before driving. Your foot will go to the floor otherwise.
