front coil replacement
96-Runner
how do i replace front coils? my driver side rear is sagging horribly and my guess from gas tank. rear axle is no big deal im use to straight axles in front not independent suspension with i believe struts?
any suggestions on type i should get? I need this thing to go over dirt roads that arent maintained and have harsh sand whoops as the jobsites i go can be horrendous sometimes. the next job from rumor is suppose to be down 12miles of dirt
You could get some adjustable coilovers. They're pre-assembled usually, so it's an easy swap in. 3 nuts on top, 1 on bottom.
But like absalom said, his link in his signature has some really good lift suggestions based on use.
Thanks Absalom on the write up ill use it when time comes.
Im not lookin to lift i would like to keep at stock height.
Just need a good recommendation on parts for sandy bumpy and divoted unmaintained county roads along with daily driving. Im not tryin to build an offroad vehicle "again"
Im shooting for the best of both world if at all possible
