Front coil settings?
Tooltime19
Getting ready to pull the trigger on some Toytec Eibach front coils. I have the Bilstein adjustables all around. Im running OME 2' rear springs. My front springs are sagged out, the front spring rate is far too soft for my style of use and now the truck looks stupid. I like to run fast powerline desert roads with small whoops ect and the front cant keep up with the rear. I use the truck, but dont beat it!
My question is; In order not to have to do the labor twice, what setting are you guys using on the Bilstein/Toytec combo up front to make the front sit level with the rear? I dont want to guess and then have to go back and adjust.
Also, just saying, if I went full lift on the shocks with the new 2" coils, will I have any issues? Issues such as the shock bottoming out and getting busted in two. Or coil bind before my available wheel travel is used up.
Thanks in advance for the help.
utkrstam
