front coil spacers
escoastrider72
just put my old man emu 2.5inch lift on and it looks and rides great. there is one problem though the back is about 1-1.5 inches higher than the front due to the weight of the bumper and the lack of weight in the rear because its a HD kit. i was wondering if any one knows a website where i can but front coil spacers to level this out and any other info will be greatly appriciated.. thanks alot
Just as an fyi, those OME kits tend to settle in a few weeks after install. Wait before you buy anything to make sure the back doesn't settle.
Also, I would inquire as to others that are using spacers w/ OME kits. If you were looking for top-out spacers, I'd understand but if you were going for a coil spacer, you may not like the ride.
Last thing, more than 2 1/2" up front is a no-no on your cv angles...
I have the strut mount spacers matched with some off-road struts all around - and damn are they stiff. If you're looking for an OE ride quality - look for some good adjustable dampers.
