jpgordon24
So yesterday I replaced my tie rod ends (inner and outer), Idler arm, and attempted to replace the front shocks and pitman arm. I started on the right front shock and the top where you put a 4 or 5mm wrench on to loosen the nut freakin broke! :gun5: I also couldn't get the pitman arm off. I broke 4 pitman arm pullers and even heated it with a torch! No luck. The steering is much more responsive, but I now have to grind off the shock bolt to get the new shocks on. Does anyone have any tips on getting the pitman arm off. Im stumped.
