Millerlm and the rotor problems
I agree that the oem rotors have had many issues and if this is
going to be an ongoing problem for you then stop wasting your
money and time on the rotors you have now. I have found that
Brembo maks an excellent after market rotor at a very reasonable
price. The company that I have done business with is Import
Replacement Parts /
[email protected] / order line: (452) 398-
1846. My sales guy is named Jeff and he is an excellent resource
person. If you mention that you are a member of the Honda-Tech
community there is an additional discount.
2. I would find a new mechanic. To pull your rotors and resurface
them and charge $400.00 is a crime. Rotors should only be cut
perhaps once or no more thab twice...NEVER 3 times.
3. Consider an upgrade to a good ceramic pad if you go with a set
of new front rotors. They are not that expensive...$40 -$50 and
will make a world of difference.
4. Consider having all your tires pulled and re-balanced. This will
cost about $10-$12 per tire and is usually money well spent.
5. If you are going thru the above expense, consider a 4 wheel
alignment. There is some rather new technology with the alignment equipment and the two places I have seen the
equipment is Firestone and NTB...National Tire and Battery.
The cost is between $40-$60 but be on the lookout for specials.
Try going to Mastercare.com for local sales and specials at Firestone.
6. At the time of the alignment and wheel balancing, make sure
that the proper and correct air pressure is put into each time. There is generally a few pounds difference between the front vs. the rear. This information cal be found in the owners manual, inside the drivers door or inside the glove compartment box.
7. Be careful for the first few hundred miles after the work is done
on the brakes. Avoid applying heavy pressure until everything is seated properly.
8. Consider working a deal with sombody to do the alignment, wheel balancing, etc all at once.
9. Have you new mechanic check your calipers so they are applying equal pressure throughout and are not frozen: unequal pressure = irregular pad wear = warped rotors.
10. Good luck and if is taken care of properly you should have many miles of happy braking.
