Front Lift Options
ChoochCharlie
As for a rear lift on a 2nd generation, OME springs seem to be the obvious first choice.
But that leaves a couple options with the front.
Most common is either a new set of torsion bars from OME, or just clocking your present bars higher.
Second option I have seen is a bushing lift. The bushing lift keeps the upper arm in the same stock position and negates the need to clock the t-bars.
Here is a source of bushing lifts from a quick Google search.
4Runner 90-95 - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
What is your experience with the different options?
Did you find in your search a real reason for one over the other?
Does changing your t-bars make a difference that is worth the extra $200 or so?
New shocks are needed for all options. A new pan hard bar is also needed.
I wonder why none of the options come with a pan hard bar. Does anything else need to be changed?
i have the ball joint spacers in mine and i love them, i wouldnt crank your t bars.... harsh ride and no flex. i have ball joint spacers (pictured above) and a redneck coil spring lift in the back and i have enough room to run 33's pretty easily. these are def the best option in my opinion.
