Hey guys, i have the OME 881/890's and it doesnt sit as level as i would like it to. Is there any way to put a spacer in the front to bring it up a little bit?
The 1/4" spacer may not need longer studs (mine did not, some studs may be shorter and may need to be replaced) (if there are threads showing after the nuts are tightened then the studs are long enough) (use locktite on the nuts)
The actual spacer thickness is 1/4" (.25"). The Lower control arm is ~14" long (pivot/alignment bolts to the ball joint CL). The shock is inboard by ~6" or 43%. A 1/4" spacer yields .3575 (or 23/64", just shy of 3/8" or .375)
A 3/8" top out spacer will yield .53625, or ~17/32" (just over 1/2 inch)
