various details and links for e-brake cable install on 92 4runner
I dealt with this, and am still dealing with it, so I wanted to put all this info somewhere. Unfortunately my new cable, ordered from rockauto, got or came with a burr in it, which then got it kinked. Now I still have the cable get caught up in the handle mechanism sometimes, especially if I'm not really slow in putting the e-brake in.
The replacement is really easy (as long as it works for you). I didn't realize early on that you replace the whole cable, including the sleeve. The toughest part is getting it off the handle, which is easy if you have all the info. Here's links with more info, but basically you remove the brake warning light button, and the pulley, and then push the front most lever on the brake mechanism (right behind the dash) while pushing in the brake level. This lets it go back an extra half inch, and lets you get the cable out easily from the mechanism, all without worrying about that pin that hits the brake warning light button, or removing anything else. After that, it's just removing a couple of brackets underneath, bending a couple others, and removing the pin at the other end. Simple....but better when there's not melting ice dripping on you.
(and yes, these links were on yotatech, but have good info)
broken e-brake cable - YotaTech Forums
Front parking Brake Cable Replacement on a '93 Pickup - YotaTech Forums
BTW, even though rockauto and others only list this part for the pickup and not the 4runner, this page on toyotapartszone shows all 89-95 4runners and pickups (not the extended cab ones, for obvious reasons) use the same part number for the cable:
46410-35650 - OEM Toyota CABLE ASSY, PARKING
On rockauto, that is part number C138652 from this page:
1992 TOYOTA PICKUP Parking Brake Cable
While it's not working 100% for me, I don't know if the burr I found existed before my initial install or not. In general it's working though.
