Front spacer installation
omegadeluz77
Does anyone have pictures or a link to the front spacer installation on a 2wd 2007 SE with XREAS? I got some 1 inch spacers from ebay and it came with intructions but I wanted something to cross reference with.
Thanks,
Joe B.
omegadeluz77 said:
http://cgi.ebay.com/ebaymotors/Toyota-FJ-Cruiser-2-LIFT-LEVELING-KIT-05-06-07-08_W0QQitemZ220397677830QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item220397677830&_trksid=p3911.c0.m14&_trkparms=72%3A317%7C66%3A1%7C65%3A12%7C39%3A1%7C240%3A1318
They show for an FJ but they worked fine. I just got done installing the spacers and front end is still 1/2 lower than the rear. He also sells the 3 inch which would be exactly level.
Do you have XREAS suspension? How much did you have to take apart to install the spacers (ball joints, sway bar, sway bar link, etc.) I want to do this but I dont' have 8 hours+ to install the Daystar spacers. It seems like these might go much easier and achieve the same result.
I have XREAS. I didn't have to take apart the balljoints. I took about 3 hours for the first side and 2 for the other. I suggest having help. J.A.'s writeup really helps. I will get pics up this evening.
omegadeluz77 said:
I have XREAS. I didn't have to take apart the balljoints. I took about 3 hours for the first side and 2 for the other. ....
Looks like you did not have to disassemble struts either. Is it correct?
No strut disassembly, but you will need to compress them to rotate the top mounting plate if you have XREAS. This is due to the hydralic lines. If you have regular struts you can just rotate the strut itself.
