front spindle
freshley
Can someone explain to me what goes through the front spindle. I'm replacing all my front bushings and thought I might do the upper ball joint and front wheel bearings being that I have over 230k miles. I know the bearings need pressed in, but are they pressed into the spindle? It sure would make things easier if they were because I could find a pair at a junkyard, clean them up and have everything set to go back in. I tried looking at the exploded diagrams and they really don't show how all this goes together.
Thanks!
Thanks!
My buddy just did this. Its pressed into the hub assembly. Even with a press he said he had a PITA time putting them in. Glad I was not doing it. LOL. Make sure you use OEM parts.
They press in. You need quite a few specialty tools / plates and such to press the bearings in properly. A HF press and a set of arbors will not get the job done alone :) Several photos and info on my refurb and rework thread on doing a bearing job.
There are also two seals that need to be put in. And IF you decide to keep your dust shields, then I would buy new ones as the stockers will often get destroyed or mangled when pressing the hub out of the bearing.
Last, it is a good time to install new wheel studs.
OEM uses Koyo bearings. I have used these guys several times and have had no issues. Fast shipping and authentic parts.
http://www.ebay.com/itm/1996-2002-Toyota-4Runner-4WD-Front-Wheel-Hub-OEM-KOYO-Bearing-Seals-PAIR-/151448728638?hash=item23430c343e&vxp=mtr
Tx470
