Front strut OEM top hat assembly- easy to find?
Flyer
I would like to replace my FJ TRD struts and shocks with new ones and I found a like-new takeoff set from a 2013 FJ locally. However, there are no coils and the struts have no coils or tophat or top mount assembly. I could reuse my springs but since there are bushings in the tophat assembly, those bushings may be shot.
I can't seem to find the top hat assembly separately. They are probably similar between several Toyota vehicles. I'd rather use the genuine OEM stuff. Where can I find these? If I can find them, I'll pick up the two struts and shocks this week. Thanks!
Thanks, I'll note down the part numbers and see if they match the FJ and Tacoma part numbers for the same thing. If so, I may be in luck. Not sure how good aftermarket bushings are. They just seem to vary in quality significantly. Like brake pads- so much junk out there. Maybe I'll pass on these struts and wait for fully assembled ones. Darn.
Thanks, that adds a lot to the $130 the person wants for the four shocks but not too bad I guess. I appreciate the link.
This is pretty encouraging. If the KYB parts are good, I am in luck. Thanks for all this info. My 4Runner now has 121,000 miles or so and runs so well that we can't bear to get rid of it. Stuff like this just keeps it in new condition.
Its the same
If I'm reading this right, the top hat setup on an XREAS suspension is different than a standard setup?
But like the OP i didnt want to re-use the OE top hats. And i knew rom installing coilovers on a 3rd gen that its a bit easier to do the job if the replacement coilovers are assembled.
Jhunt
